How to identify only end with upper case latter's
tomjerry.vl
Only Identified End with Upper case latter
For example identified below highlighted yellow color indicated words words
NameIdentification 2 A 2 A 3 D 3 Dhbsv 5 G hbsv 5 G g 6 Gsgdsgg 6 Gsgdsgt 56 Fgdsgt 56 Fgdsgtd 9 Dtd 9 D
Best answer by redgeographics
You can use a StringSearcher to search for the regex [A-Z]$ (do make sure you set it to Case Sensitive)
Forum|alt.badge.img+35
  • February 5, 2020
A string searcher with regex [A-Z]$ with case sensitive set to YES
Forum|alt.badge.img+49
  • February 5, 2020
tomjerry.vl
  • February 5, 2020
How to use this expression "regex [A-Z]$" in Tester please tell me
If you want to use a Tester (or TestFilter) this is the way to do it
tomjerry.vl
  • February 5, 2020
Thank you giving your answer I am asking one more question how use "Replace Regular Expression" in String pair replacer please tell me
  • February 5, 2020
The StringPairReplacer won't work with regular expressions, unfortunately.
tomjerry.vl
  • February 5, 2020
But how to change exact multiple words string pair replacer
note:not combination words changed only exact words
novenoverantagrd rocknovenovember
rockmoon
fuzzyrock
rock
I think you had me beat by a few seconds so I'm going to accept this answer as well
tomjerry.vl
  • February 7, 2020
Not only two words. different types of words how to change like as string pair replace
