coordinate system transformation
When using the Reprojector transformer FME logs the transformation in the log file. Below is an example from a log file: Reprojector: Using transformation `NAD27_to_NAD83_Canada_FME,Forward(Grid File Interpolation,EPSG:1313)' when reprojecting from LL-27 to EPSG:4326 Is there any way to ``capture`` the transformation used in an attribute or anything that can be written out? Thanks, CA
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
