Decomposing attribute table.
  • February 15, 2016
  • 10 views
Hello.
I have shapefiles as the source of my data. I have no knowledge of what the attributes in the shapefile are going to be.
What I need to do is to create an object (table row) , where for each object(row) I will have only one property and it's value (basically the oposite process of aggregator).
for example - the original (incoming) data are:
id1, property1_value, property2_value, property3_value
id2, property1_value, property2_value, property3_value
What I am trying to get:
id1, property1_name, property1_value
id1, property2_name, property2_value
id1, property3_name, property3_value
id2, property1_name, property1_value
id2, property2_name, property2_value
id2, property3_name, property3_value
Any help would be really appreciated. Thanks,
Radek
Best answer by takashi
How about this?
Rename property1/2/3_name into "prop{i}.value" and create "prop{i}.name" (i = 0, 1, 2).
Then, you can decompose the "prop{}" list with the ListExploder.
Forum|alt.badge.img+19
  • February 15, 2016
How about this?
  • February 16, 2016
takashi wrote:
How about this?
Good answer, however I am not good with loops and scripting - there are going to be many more attributes, and I have no idea the exact number.
I have found a solution - use AttributeExploder followed by AttributeKeeper and id does exactly what I needed.
Thanks!
