FME: How to consolidate all the feature classes not committed to anywhere?
  • May 26, 2013
  • 4 views
May I know how can I find all the feature class that has not been committed after a run?
Yes I know how to save those feature that have error/ignored by setting the writter but there are those that are miss out because they are not commited anywhere.
I do not wish to manually route them to a database or shape files because it can be quite a tedious task.
May I know if there is anywhere to say all feature classes not saved to be commited into a file or database table?
Best answer by seesee
May I know how can I find all the feature class that had not been committed after a run?
Yes I know how to save those feature that have error/ignored by setting the writer but there are those that are miss out because they were not commited anywhere.
  • May 26, 2013
