ShortestPathFinder - tracing through multilevel line crossing
lazarlubomir
Forum|alt.badge.img+7
Hello everyone,
please, I just wanna use ShortestPathFInder to find shortest path between 150 points. FME needs to get clean road (line) topology to get right path. But, Ive got road network, where are tunnels and bridges that crosses roads on surface.
Please, is there any way, how to compute path which uses bridges, tunnels and roads on surface together?
I have experience that FME can trace path only network at the same level, or am I wrong?
Thank You so much!
Lubo
Best answer by gio
@lazarlubomir
Ok edit it.
I looked up the part of my workspace.
it uses only 1 topologybuilder. (contrary to my earlier statement)
Basicaly enter your network. Bridges and tunnels etc. must be identifiable.
There is a bit for "inline" bridges.
It makes a clean network excluding bridges etc.
Then creates a new network inculding bridges and the clean one using tpologybuilder with setting "assume network is clean"
It is a Dutch, i 'm too lazy to ranslte my words atm..
ntwrk2forum.fmw
Hope youll manage.
Greets,
Gio
erik_jan
Forum|alt.badge.img+18
  • April 8, 2020
The ShortestPathFinder does not seem to have an option to ignore different levels.
But would it be an option to create 2D data, using the 2DForcer for this purpose?
I do think this would be a great addition to the transformer and I would vote for the idea if you post it on this Knowledge Board.
Hope this helps.
gio
Forum|alt.badge.img+15
  • April 8, 2020
@lazarlubomir
Ok edit it.
ntwrk2forum.fmw
Hope youll manage.
Greets,
Gio
gio
  • April 8, 2020
the point with using elevation levels is that "one has to climb the ramp" sometime.
Tried that different ways.
Making a clean network without bridges and tunnels and then reacreateit including them was easiest solution i found.
Have not knowledge what the common solution might be. Must google it someday.
Forum|alt.badge.img+35
  • April 8, 2020
I'm unclear what you're asking for - you want the shortest path finder to take a path which involves jumping off a bridge onto the road below?
I spent a long time trying to cleanse a highways network which had z values but nodes inserted where roads crossed even if not on the same level...
@lazarlubomir If your network is 'clean' then you can use the TopologyBuilder with the Advanced Parameters > Generate From = End Nodes - as described here . This means your bridges / tunnels should not be noded where they cross roads. If you need to remove the nodes, then you can use the the ideas suggested by @gio above, or by @takashi in this post.
You only need to remove the vertex from one of the lines, so for bridges/tunnels, you could probably safely remove any interior vertex and only keep the end points.
Here's an example of an approach I used to clean an electric network: ArcGIS_GN_Remove Duplicate Nodes v00.fmw
gio
  • April 8, 2020
@ebygomm
he wants to prevent nodes where a bridge,tunnel, viaduct crosses a road.
Because then you would indeed possibly "jump of the bridge" .
I LOLed at that :)
thats what the bit i made does , as i was less inclined to send people to their doom...
  • April 8, 2020
gio wrote:
@ebygomm
I LOLed at that :)
I did wonder :-) Topologically correct road networks become a bit of a nightmare when you start dealing with things like this, lots of bridge jumping!
Source: Top 40 most complex junctions
lazarlubomir
  • May 28, 2020
@gio, Finally, Your supposed solution with creating topology twice - one time without tunnel/bridge and second time with tunnel/bridge is suitable for me. Before it, I had to detect line crossings by SpatialRelator and eery crossed line got an attribute CROSS=1, so I was able to split tunnel/bridge and ground parts of roads.
lazarlubomir
  • May 28, 2020
Hope this helps.
Hello @erik_jan, thank You! , My data arent in 3D, I have to detect if there are crossings between them or not. If Yes, it means, thet his road is tunnel/bridge. Finally, @gio supposed solution helped me.
lazarlubomir
  • May 28, 2020
Hello @ebygomm thank You for Your time! Finally, @gio supposed solution helped me.
lazarlubomir
  • May 28, 2020
Hello @markatsafe, as You wrote, the End nodes parameter helped me, but before it, I had to detect crossings between lines by SpatialRelator. Then, I used supposed solution of @gio - create topology twice - once without tunnel/bridge in End nodes and Intersection regime and then in End nodes regime including tunnels/bridges. anaway, thank You so much for Your time!
@lazarlubomir Thanks for letting us know this worked out. A team effort (sadly I don't think they award team badges on the Community!)
gio
  • May 29, 2020
@lazarlubomir
Pleased to help out. Glad to hear you managed it.
Greets.
Gio
