json arrays/list related by index to excel file
  • November 30, 2017
  • 11 views
I have a json file with 3 lists. Zip Code, Occupation Code and Number of Jobs. The index of each array is related to the two other lists by index. I've posted a screen grab. How do I write these to excel such that the columns are ZIP, Occupation Code and Number of Jobs? I have tried hours of experimenting. Thanks in advance for help.
jdh
Forum|alt.badge.img+28
  • November 30, 2017
There is probably a better answer involving jquery, but you could doubly fragment the json and then recombine the resultant features using the second (rows) json index.
jsonpivot.fmw
