inspection point cloud on DTM
I want to compute the elevation of each point of a point cloud on a DTM.
Is it possible to compute le Z distance?
thanks a lot
Nicolas
fmelizard
Forum|alt.badge.img+17
  • June 20, 2013
The SurfaceModeller transformer allows you to drape features on the surface model created. Send your points into the DRAPE_FEATURES port. The elevated points will be output from the DRAPED_FEATURES port.
  • June 24, 2013
Yes I tryied it, but it doesn't works.
I put one point cloud as input from points/lines (wich is the ground) and one point cloud as drapped features (wich is vegetation).
And as output for drapped features I put one point cloud too. I want XY from the vegetation and Z interpoled.
what kind of features must I use?
thanks
