split line feature where the point exist
  • July 25, 2023
  • 8 views
Forum|alt.badge.img+5
Hi Team,
I have a electric lines and electric devices . I want to split the lines where the device exist . I used the point on line overlayer with 0.001 tolerance . But its creating many new lines with 0.001 feet (less than a feet) lines .Ideally this shouldn't be . Its creating the issues when building the Utility network . can you please help me on this ?
geomancer
Forum|alt.badge.img+47
  • July 25, 2023
So probably there are short overshoots in your data. You can remove lines shorter than a certain length with a Tester or a TestFilter. Would that help?
