Archived
GeographicBufferer should have Dissolve on Attributes parameters
Related products:FME Form
jdh
The Bufferer transformer has the parameters Dissolve On Attributes, Dissolve On Attributes Mode and Generate Dissolve List. It would be nice if the GeographicBufferer had these parameters as well.
