Can you recover deleted FME Engine logs?
  • November 12, 2021
  • 12 views
timboberoosky
Is there a way of recovering FME Server Engine logs that have been deleted? In the Web UI, I downloaded all (current and old folders) as a backup, and didn't notice until after I had chose to delete the same folders, that the download had some 'network issue' and didn't actually download anything.
Is there a way of recovering the log files that were in 'current' and 'old' that I have deleted? They aren't in the Recycle Bin on the FME Server machine.
Thanks!
  • November 12, 2021
Not from FME, no.
But there are a lot of companies specializing in these type of services, look for data recovery services in your area.
timboberoosky
  • November 12, 2021
Thank you @david_r​ . We do have an onsite storage team that should be able to recover for me, I was just wondering if there was a quicker/easier way through FME tools.
Thanks!
