JAVAX Error When Saving FME Server Automation
pmcpherson
Forum|alt.badge.img+9
Am encountering an odd "javax.crypto.IllegalBlockSizeException" error when I try to save an Automation. There seems to be some issue with the associated workflow, however the workflow runs fine by itself, or via a schedule.
Has anyone else encountered something similar?
Hi @pmcpherson
Does the automation save/start if you remove the / from the name?
pmcpherson
  • June 18, 2019
Jennifer,
Am still not sure what the error means exactly, but I was able to relate it to a password published parameter that was not importing correctly from the associated workspace. I was able to get the Automation to save/run by manually overriding that password parameter within the Automation dialog, although it was touchy in that it kept resetting.
Phil
nic_ran
Forum|alt.badge.img+16
  • April 28, 2020
This appears to be a bit of an issue with Automations. From my observations, it would appear that all password entries need to be re-entered any time a change is made to any of the published parameter values for the Automation. So, for example, if I just want to update a non-password parameter, I also need to update all password params. I don't think this should be the default behaviour.
pmcpherson
  • April 28, 2020
Yes, the problem persists. Hopefully the Safe folks will add it to the bug-fix list for the next release. Thanks for commenting.
jovitaatsafe
Forum|alt.badge.img+11
Hi @nic_ran and @pmcpherson,
It looks like this error message, tracked in an internal issue as (FMESERVER-14633), has been resolved for FME 2020.0.1 in the latest release, which can be downloaded here: safe.com/downloads
Please give that a try and let us know how it goes for you!
pmcpherson
  • May 5, 2020
Jovita,
I've upgraded to FME Server 2020.0.1 and so far the error has not reappeared. Will advise if it shows up again. Thanks.
Phil
nic_ran
  • May 22, 2020
That's great news. Unfortunately, I don't have simple access to install a newer version of FME Server but will try to test it soon...
