How to: Transposing/concatenating problem.
Can't wrap my head around the following reformatting problem. My data looks like this:
Pointid substance1 substance2 substance3...
1 value
2
3
I have a lot of columns in the original data, almost 200 different substances. I would like to achieve the following structure (below) where Substances attribute contains all values of 200 substance columns and is exploded for each Pointid. So basically every Pointid is replicated for each substance and values column have the value of each substance. I've tried multiple combinations of transformers but without result.
Pointid Substances values
1 Substance1 value
1 Substance2 ...
1 Substance3
2 Substance1
2 Substance2
Best answer by nielsgerrits
nielsgerrits wrote:
I think you can solve this with an AttributeExploder.
Attached sample workspace.
AttributeExploderSample
nielsgerrits
nielsgerrits
  • January 28, 2022
Forum|alt.badge.img+19
  • January 28, 2022
Hi @japeki​ , alternatively you can use the ListPolulator to populate all the values of Substance* attributes into a list attribute.
listpopulator-example
  • February 15, 2022
This seemed to work thank you! I've tried AttributeExploder before but somehow didn't get the same result.
