When trying to Batch Deploy my simple Geopackage files to AGOL the 'Next' button never gets possible. It wants a path to the files to be written. Is it not possible to use Batch Deploy to upload to AGOL or what am I missing?
Batch Deploy won't write to ArcGIS online
Best answer by rahulsharma
Hi @anders_d,
Unfortunately, Batch Deploy is a bit old now, as it is from a time when FME was mostly Files and folders data types and no Web Services were involved. That is most likely the reason why the "Next " button is disabled ( I can investigate this with our dev team).
Workaround
In your case, the best solution is to use Workspace Runner solution which will have 2 workspaces
1. Control Workspace (Pass the name of each file)
2. Processing Workspace (upload the data to AGOL)
This article is good start point https://knowledge.safe.com/articles/1469/batch-processing-using-the-workspacerunner-1.html
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
