S3Connector Download rejecting all files
I am trying to download a set of GZIPPED log files from Amazon S3
The file listing is working but the downloader rejects all files.
In my logs I see:-
S3Connector_CATCHER (TeeFactory): Cloned 1 input feature(s) into 2 output feature(s)
S3Connector_ROUTER (TestFactory): Tested 112 input feature(s) -- 112 feature(s) passed and 0 feature(s) failed
S3Connector_OUTPUT Feature Counter -1 6 (TeeFactory): Cloned 112 input feature(s) into 112 output feature(s)
S3Connector_INITIATOR Feature Counter -1 2147680258 (TeeFactory): Cloned 1 input feature(s) into 0 output feature(s)
S3Connector_<REJECTED> Feature Counter -1 2147745794 (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
S3Connector_2_CATCHER (TeeFactory): Cloned 112 input feature(s) into 224 output feature(s)
S3Connector_2_ROUTER (TestFactory): Tested 112 input feature(s) -- 0 feature(s) passed and 112 feature(s) failed
What am I doing wrong here?
  • July 7, 2020
I fixed this and it is down to my misunderstanding as toy the difference between download as FILES or FOLDER
If I select Download As: Folder in the destination parameter box then the files are downloaded.
I'm still confused as I had thought the file listing passed a set of files to the downloader?
jovitaatsafe
Forum|alt.badge.img+11
Hi @davebarter,
Glad to hear that you got it working! From what I understand of the S3Connector, if you are wanting to download multiple files, downloading as a Folder is the way to go. Downloading as File would only allow you to select a single file, which means it reads from a single URL.
Hope that clears things up a bit!
