Column Aligned Text (CAT) in a Feature Reader missing dataset and basename attributes - 2019.2
softwrite1
I thought I would check here first to see if anyone has seen this issue - before I log it with support.
The Column Aligned Text (CAT) reader embedded in a Feature Reader is missing the fme_dataset and fme_basename attributes - even though they are specifically exposed. I am using FME Desktop version 2019.2 (build 19801 – WIN32).
This was working fine in the last version of 2018.
Thanks in advance.
Mike B.
Best answer by softwrite1
All,
I have now submitted this issue to support - case number is C150893. Will update this when resolution is received.
Thanks - Mike B
softwrite1
  • December 31, 2019
All,
Thanks - Mike B
fmelizard
Forum|alt.badge.img+18
  • January 7, 2020
softwrite1 wrote:
All,
Thanks - Mike B
Hi @softwrite1 See the workaround posted in https://knowledge.safe.com/questions/105379/where-are-the-fme-dataset-and-fme-basename-attribu.html
