Python API for PointClouds
  • January 30, 2015
  • 11 views
Is there a way to manipulate PointClouds object using the python APIs. I couldn't find any documentation on FMEpedia. Thanks for the help
  • February 2, 2015
as far as I know, manipulating rasters or point clouds isn't possible using the Python API, only vector and attribute data.
Consider contacting Safe support (https://safecommunity.force.com/knowledgeSubmitCase) to add your name to the enhancement requests for these, it might accellerate the priority.
David
gio
Forum|alt.badge.img+15
  • February 2, 2015
there has been a python-pcl binding for pointclouds sinc 2013. Any use to you?
http://www.pointclouds.org/news/2013/02/07/python-bindings-for-the-point-cloud-library/
Google-search it, there are more tutorials and such.
For rasters, maybe this is usefull to you?
http://www.maths.lancs.ac.uk/~rowlings/Software/Qgis/Plugins/rasterlang/index.html
