Add blank line between field names and data into CSV Writer
farfar
Forum|alt.badge.img+11
Hi All,
I look for a method that can add a blank line between field names and data into CSV Writer.
Any idea?
Thanks an advance.
FarFar
Forum|alt.badge.img+19
  • December 11, 2014
Hi FarFar,
There may be several ways.
An easy way:
Add a Creator transformer to the workspace and connect it to the CSV writer.
Geometry Object: Null
Number to Create: 1
Create At End: no
But the CSV writer will write commas anyway. If you don't want to write commas, the solution will be a little more complicated.
Wouldn't you like to write commas into the line?
Takashi
farfar
  • December 11, 2014
Hi Takashi,
Thank you for your response.
No. I don't like to write commas into the line.
FarFar
gio
Forum|alt.badge.img+15
  • December 11, 2014
Does'nt CSV always need a separator-character?  (wether it be comma or one of the other options)
Space would need be enclosed in these separators.
Maybe you should write it as a txt. And use 2 or more spaces as separator.
 ( and make sure attribute values have max. 1 space in succesion max, if at all)
Entering 2xnewline character for blank line is of course not an issue, thats easy.
  • December 12, 2014
Remove the CSV writer; add a Text File writer instead.
Insert a StringConcatenator before the writer to create a csv line (comma-separated attribute values) for each feature. Set the concatenated attribute name to "text_line_data".
Add a Creator to create a feature; connect an AttributeCreator to add an attribute named "text_line_data" to the feature, set the value to comma-separated field names followed by one newline character. And then send the feature to the writer.
Note that a value should be surrounded by double quotations before the concatenation if it contains a comma.
farfar
  • December 12, 2014
I'm following you method but i dont show a blank line !
this is my example to do it :
Any idea?
Thanks an advance.
Farfar
  • December 12, 2014
One possible reason is that the newline was not set properly. But it cannot be checked in the screenshot.
  • December 12, 2014
This is an example of setting the field names + a newline character with the AttributeCreator in FME 2013.
farfar
  • December 12, 2014
I did exactly the same but i haven't the blank line between fields names and data!!
FarFar
gio
  • December 12, 2014
You need to have two newlines in a row for a blank line....
gio
  • December 12, 2014
ok, that did'nt work either.
How about this then?
If you dont want last blank line, remover last line_number...after sorting.
farfar
  • December 12, 2014
Always KO.
i add 2 newlines likes :
  • December 13, 2014
Good to hear you've accomplished it.
I was able to get the required result with just one newline character, so I'm not sure why you had to add two newlines.
I tested it with FME 2014 SP4 and 2013 SP4.
Which version are you using?
farfar
  • December 16, 2014
FME 2013 SP2.
My problem is not resolved :)
i will migrate to SP3 to test if its OK.
Farfar
farfar
  • December 16, 2014
i'd say to migrate to SP4
farfar
  • December 17, 2014
I installed SP4 but my problem isn't resolved !
Any idea ?
Thanks
farfar
  • December 17, 2014
Any idea ?
  • December 17, 2014
Check if this example works in your environment.
Download (https://drive.google.com/file/d/0B0ufVP2t0eApVXl3V21kZ1AzX1k/view?usp=sharing)
I can always run it successfully with FME 2013 SP4.
farfar
  • December 17, 2014
Thanks a lot Takashi. It works your example.
I compared a two workbench and the difference is that my writer is saved as a txt file. So no blank line between fields names and data.
If a specify that is a csv file writer, it works like your example.
Thank you.
Farfar
farfar
  • December 17, 2014
Erratum :
I compared a two workbench and the difference is that my writer is saved as a txt file with .txt extension. So no blank line between fields names and data.
If the writer is a text file WITH CSV EXTENSION, it works like your example.
Thank you.
Farfar
gio
  • December 17, 2014
the workspace pic i posted inserts a blanklines into a txt file (no csv extension needed). Try it out.
