I was wondering if it is possible to trigger an FME workspace to run automatically if there has been an edit to a Reader feature?
I thought maybe the FMEServerNotifier transformer but don't think it is the right method..
Thanks,
Thanks,
Best answer by mark2atsafe
On Server, I would use the File/Directory watch notification. Then if the date changes on a file in the directory the notification can trigger a workspace.
