Is there a way to search FME Universal Viewer by Zip Code?
  • March 12, 2019
  • 6 views
I would like to search by zip and for the Zip Code area would be returned on the map. Please advise, Thanks!
erik_jan
Forum|alt.badge.img+17
  • March 12, 2019
If the ZIP code is an attribute on your data, you can use the Filter option (menu button) to show only those geometry objects that have the filtered Zip Code.
