Importing h5py into python caller
Does anyone know if there is a way to import h5py into python caller for fme 2018.1?
numpy imports fine but importing h5py produces the following error:
Python Exception <ImportError>: cannot import name '_errors'
Error executing string `import<space>h5py'
Factory proxy not initialized
PythonCaller_2(PythonFactory): PythonFactory failed to process feature
Error encountered while calling method `input'
PythonCaller(PythonFactory): PythonFactory failed to process feature
PythonCreator(PythonFactory): PythonFactory failed to process feature
Any and all help is greatly appreciated!
  • June 12, 2019
The easiest solution is probably to install a regular distribution of Python (e.g. from python.org) and manually install the h5py module(s) there. Then set FME to use that Python distribution:
https://knowledge.safe.com/articles/814/choosing-a-different-python-interpreter-installati.html
Hi David,
That was one of the first things I tried and it did not work sadly. Do you have any other suggestions?
  • June 12, 2019
Can you please be a bit more specific as to why it didn't work? Error messages, logs, screenshots, etc?
