Has anyone been able to setup a outgoing webhook from MS Teams with a message that can then be passed into a parameter?
  • December 23, 2022
  • 37 views
oliver.morris
Forum|alt.badge.img+12
Hi, I have a number of outgoing webhooks from MS Teams that call tasks to run in FME Server that then respond back with a message in MS Teams. That's great but I would also like to be able to pass messages into parameters. e.g. From MS Teams send this: @FME Server 'check this'
The 'check this' could then be received into a new parameter and used by a workbench job.
Has anyone had any luck doing this? Many Thanks!
oliver.morris
  • December 23, 2022
@jlutherthomas​ any ideas, this article has been super useful btw but doesn't cover this example. https://community.safe.com/s/article/How-to-use-the-MicrosoftTeamsConnector-transformer
