Aggregate only multipart geometries (or deaggregate only single part geometries)
  • January 27, 2022
  • 120 views
runneals
Forum|alt.badge.img+22
I have a bunch of records with a GroupID attribute on them. Some GroupIDs will only have a single record/geometry, while others will have multiple records/geometries. When I use the Aggregator, it aggregates ALL the records, even the ones that only have a single geometry part.
How do I either aggregate only the truly multipart aggregates or deaggregate only the single part aggregates?
Best answer by daveatsafe
Hi @runneals​,
After the Aggregator, please use the GeometryRefiner transformer, which will convert the single geometry features to simple, while leaving the multi-geometry features as aggregate.
daveatsafe
Forum|alt.badge.img+19
  • January 27, 2022
Hi @runneals​,
runneals
  • January 27, 2022
daveatsafe wrote:
Hi @runneals​,
@daveatsafe​ You're a rockstar! Literally tried every other combination of transformers except that one :P
