XML Loading Error
Can someone please help me load this XLM file to FME?
I am new to this tool and trying to convert this XML to Excel.
danilo_fme
Forum|alt.badge.img+45
  • April 11, 2018
Hi @reyfernan,
I created the template Workspace reading your xml file to excel file.
Attached the file - workspace-xml-to-xls.fmwt
Thanks,
Danilo
  • April 12, 2018
Hi @reyfernan, FME provides many ways to read and translate XML. Which way you should go, all depends on your requirements - e.g. which XML elements should be retrieved as features, which XML elements/attributes should be extracted as feature attributes, and so on. It's hard to find a solution unless you clarify your requirements more specifically, and also it may be hard to explain the requirements appropriately unless you have basic knowledge on how FME treats XML.
So, I would recommend you to learn first the fundamentals on how you can read, translate XML with FME. There are many articles regarding XML in the Knowledge Base, and I think this one would be a good starting point: Tutorial: Getting Started with XML
danilo_fme
  • April 15, 2018
danilo_fme wrote:
Hi @reyfernan,
Thanks,
Danilo
Hi @reyfernan
Did you checked the Workspace?
Thanks,
Danilo
