Python startup script to operate on an unpacked zipped File Geodatabase input
bruceharold
Forum|alt.badge.img+17
I have a GEODATABASE_FILE reader set to a ZIP file path.
I want to run an ArcGIS geoprocessing tool on the contents before the workspace runs, using ArcPy.
I can see the data unpacks to AppData\\Local\\Temp\\FME_TempFileStore_* directories.
Is it possible to access the unpack location in Python? I can't see the path exposed in FME_MacroValues.
Best answer by mark_f
Different approach?
Why not unpack in Python inside the Workspace before running ArcPy, then reading with a FeatureReader.
  • March 30, 2017
Different approach?
itay
Forum|alt.badge.img+16
  • March 30, 2017
mark_f wrote:
Different approach?
Yes I doubt the temp location will be a possible solution, I would use the start up script to unzip or do that in a python transformer before using arcpy.
bruceharold
  • March 30, 2017
Hi, yes I can always unzip but that undoes the goodness of using a zipfile 900MB (in my case) in size and then having to clean up. I need to pivot a table with 10M rows, SQL isn't an option but arcpy. PivotTable_management works great. I'm grasping at straws here :-)
  • March 31, 2017
If you unzip your data to the directory path created by the TempPathnameCreator, the contents will be automatically deleted when FME terminates (just before the shutdown script). You can e.g. use the ZipExtractor or the Unzipper from the FME Hub, should be pretty easy.
bruceharold
  • March 31, 2017
Thanks David, good tip, I didn't know TempPathnameCreator.
  • March 31, 2017
It's one of those hidden goodies!
