How could i write the exceded rows from oracle file to excel file each part in different sheets
  • March 26, 2020
  • 8 views
gogopotter90
Forum|alt.badge.img+13
How could i writ the excedded rows from oracle to excel files
if it is not enough in one sheet can i write all data ins the oracle file to different sheet and eaxch sheet has part of the data from Oracle file till the data finished .Is it possible
or which another format could i write the exceeded rows from oracle fiels to
Thanks for any help
Best answer by alyssaatsafe
Hi @gogopotter90, would writing to a CSV (Comma-separated Value) file be an option for you? Or is there anything else you wanted to achieve with Excel format?
  • March 30, 2020
