New x64 FME crashing
  • July 17, 2018
  • 10 replies
  • 166 views
kimo
Forum|alt.badge.img+10
Problem signature:
Problem Event Name: BEX64
Application Name: fmeworker.exe
Application Version: 2018.7.34.18310
Application Timestamp: 5b03ca3e
Fault Module Name: StackHash_761b
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 000007fe7ee0124b
Exception Code: c0000005
Exception Data: 0000000000000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 5129
Additional Information 1: 761b
Additional Information 2: 761b8286f685b3d40ac141f6068cfeb6
Additional Information 3: c89c
Additional Information 4: c89cd562f414498be5c93ca53b0dbbf9
I am running Windows 7, ArcGIS 10.6, ArcGIS Pro 2.2, 64 bit Python extension, FME 32 and FME64
I have reinstalled, repaired and upgraded everything.
I have read all the old notes about clashes with 64 and 32 bit.
This crash happens with no FME errors when I simply generate a new workspace. If I close the system crash box (pasted above) the workbench carries on as normal, until it crashes after running, but again I can simply dismiss the box and it appears to have finished normally.
This does not happen if I open 32 bit FME.
On an identical setup on my laptop (but Windows 10) I do not get the crashes.
Best answer by andreaatsafe
Hi @kimo,
I'm wondering if this is linked to this problem here that was reported for Windows 7: https://knowledge.safe.com/articles/63592/fme-exe-has-stopped-working-after-updating-windows.html
Perhaps check to see if you have these window updates installed: KB4056894 and/or KB405689
If so, you may want to try the two solutions suggested in the article to see if it fixes the issue with FME 64-bit.
- Andrea
I am running FME(R) 2018.0.1.1 (20180615 - Build 18312 - WIN64) with Windows 7 Professional on a Dell Laptop. I am getting "Error running translation." for the most simple translations from MIF to KML.
Occasionally I get Translation was SUCCESSFUL but if I run it again immediately without making a single edit it fails again.
Do you think I should try 32 bit FME instead?
mark2atsafe
Forum|alt.badge.img+59
Hi @giarcnomis - I think it would be a good idea to submit the log file to our support team (or paste it here if possible). I'm sure there must be something else in the log that explains why the translation has failed. A quick guess would be a lack of disk space/memory, or a permissions problem writing to a particular folder. Anyway, I think the log would be useful as a first step to diagnose your issue. Use safe.com/support if you want to submit it in private.
mark2atsafe
Hi @kimo - does this occur on every new workspace, regardless of format? I run 32 and 64-bit on Windows 7 without issue, but I don't have the same ArcGIS software installed, so I can't say for sure whether that is the problem or not. I have heard of a couple of problems with the ArcObjects Geodatabase R/W with ArcGIS Pro 2.2. Is that the format you are using in these workspaces?
andreaatsafe
Forum|alt.badge.img+15
  • July 17, 2018
Hi @kimo,
- Andrea
Hi @Mark2AtSafe, I had an FME support team member Nampreet look at my workspace and log files.
I have 202 Gb free disk space.
I just ran a quick one now so I could share it with you using the 32 bit FME.
As far as I can tell it isn't a problem with my data.
I think you may be right about it being a permissions problem.
mif6ogckml.fmw
log.txt
kimo
  • July 17, 2018
I don't have the problematic Windows updates listed but I have upgraded to 10.6 WITHOUT installing the 64bit geoprocessing patch after installing the 64 bit python extension. Installing the patch fixed the crashing. https://support.esri.com/en/download/7579
What is surprising is that we need to keep installing the patch after every update! The patch has versions dating back to 10.1. The problem has been surfacing since 2009 according to the datestamps on Knowledgebase. Thanks to all the support on this problem, it has been a lot of time on fruitless searching.
mark2atsafe
mif6ogckml.fmw
log.txt
Hi. Well I looked at the log file and I can see the workspace finished reading data without problem. With no blocking transformers in the workspace it would already be writing data by the time the reader finished (in fact I believe it would have already written all the data except the final feature). So I doubt it's a permissions issue, but you could obviously test that by writing to a different folder. My other suggestions are to try running the workspace with feature caching turned off, in case it's the caching rather than the writing that is causing the problem. Also try using the Writer Redirect parameter (in the Navigator window, under Workspace Parameters > Translations > Reader/Writer Redirect) to see if the translation will complete if the data isn't being sent to the writer (try Redirect to FFS File and Redirect to Inspector). I know these don't solve the issue, but to be honest, at this point I think we'll need a developer to step in and help diagnose the exact cause. But if we can narrow down where the problem occurs it will help speed up that process. I've been in touch with Nampreet and he knows what is going on. If you can send your results to him as well as here, then he can talk to the developers directly if necessary.
Hi @Mark2AtSafe I have run your suggestions and it resulted in a ffs file being produced each time it was Redirected.
When I Inspect the FSS file with FME Data Inspector 2018.0 it records the following errors:
The FFS file `C:\\Users\\scraig\\Documents\\FME\\FFS\\Test1.ffs' failed the CRC check. It is corrupt, and cannot be read
Failed to specify the feature index as constraints on the reader
The FFS file `
When set to Redirect to Data Inspector it fails to open.
A recover file is also placed into the Workspaces folder.
See attached.
mif7ogckml.fmw
rtsison.txt
ffsison.txt
ffs.txt
The FFS file `
See attached.
mif7ogckml.fmw
rtsison.txt
ffsison.txt
ffs.txt
@Mark2AtSafe I have now done a clean re installation of FME 2018.1 but I'm still getting Error running translation.
A windows error report was produced the first time I ran the new 2018.1.
I have received the following windows message.
Files that help describe the
problem:
C:\\Users\\scraig\\AppData\\Local\\Temp\\WER5772.tmp.WERInternalMetadata.xml
C:\\Users\\scraig\\AppData\\Local\\Temp\\WER7677.tmp.appcompat.txt
C:\\Users\\scraig\\AppData\\Local\\Temp\\WER77FE.tmp.mdmp
Read our privacy statement
online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid;=0x0409
If the online privacy
statement is not available, please read our privacy statement offline:
C:\\Windows\\system32\\en-US\\erofflps.txt
Attached are the temp files referred to in the windows message and the files from running the translation.
wer7677tmpappcompat.txt
wer5772tmpwerinternalmetadata.xml
parks-mif2ogckml.fmw
parks-mif2ogckmllog.txt
runneals
Forum|alt.badge.img+29
  • September 27, 2018
FYI for those of you looking for the patch for 10.6.1, it looks like they merged desktop/server into one: https://support.esri.com/en/download/7639
