Using the Reprojector it's easy to do the first part, simply select "Read from feature" as the source coordinate system. However, how do I get back to the original source CS in the 2nd reprojection?
I tried saving out the CS prior to the original reprojection using a CoordinateSystemExtractor but the 2nd reprojector won't accept it's destination coordinate system from the value of an attribute...
I'm using FME 2012 SP3.
thanks,
Nic
