Hi all
I have FME Flow installed in production environment with 2 nodes (Fault-Tolerant installation).
I have now 4 workspaces that i have scheduled every 4 minutes.
My DB Administrator see many query like this
UPDATE fme_node_health SET modifieddate = :1 , expirydate = :2 , timeout = :3 , expiry = :4  WHERE process = :5  AND name = :6
UPDATE fme_lock SET val = :1 , uuid = :2 , expiry = :3  WHERE lock_key = :4  AND (uuid = :5  OR expiry < :6 )
They occours more time and and fill the disk space dedicated to Oracle logs.
It's the first time it's happened to me and I don't understand if it depends on the scheduling or the Fault-Tolerant type installation.
Can someone help me?
Thanks a lot
What frequency are you seeing these updates? Looking at a sever I have access to I can see it updating various rows every ~15s.
Seems appropriate as these table appear to be keeping track of the various components of the Fault Tolerant setup
Thank you very much for the reply.
In fact the frequency is similar to yours.
The problem of the Oracle logs then disappeared: in reality we were releasing many components into production and when checking some things the DB admin raised this question to me because he saw a lot of writings by FME.
Another question: is it possible to configure this write parameter to the DB that you know of?
Thanks
Having a cursory look through the config files, I can’t find anything that seems to control that frequency.
I really don’t think it should change, if anything I’m surprised it only appears to checking fault tolerance every ~15s, I’d have expected it to be more frequent than that.
@rylanatsafe or @siennaatsafe might have some input or be able to get someone else from Safe to chime in
Hi @nicol.ricci and @hkingsbury,
Thanks for tagging us Hamish.
@nicol.ricci I spoke to our support team about this and it would be helpful if you could create a case. You can create a case for us here: https://support.safe.com/hc/en-us/p/Support
There’s likely some improvements we can make in our internal health check process to not log to the database, or to do it less frequently.
Hi
I will talk about this with my team and probably i will open a case.
Thank you all
