Archived
FEATUREMERGER Join On parameter documentation
Related products:Transformers
  • siennaatsafe
    siennaatsafe
  • nielsgerrits
    nielsgerrits
  • ebygomm
  • bruceharold
    bruceharold
  • geospatiallover
Please improve transformer documentation specifically on the Join On parameter. @takashi provided a good on his blog: http://fme-memorandum-takashi.blogspot.com/2013/10/join-on-parameter-of-featuremerger.html. It would be nice to include links to samples, if any.
nielsgerrits
Forum|alt.badge.img+54
The link is defined incorrect. Should be:
http://fme-memorandum-takashi.blogspot.nl/2013/10/join-on-parameter-of-featuremerger.html
I do this a lot. Create a constant attribute before Requestor and Supplier to merge constant.
fmelizard
Forum|alt.badge.img+18
  • December 30, 2016
We are in the process of redoing all the transformer documentation. I've passed this excellent idea on to the team.
