Hi, Is there a way, I can force FME workbench to use a Database Edition license rather than an ESRI Edition license, considering I have both versions?
Force FME desktop to use a particular Edition
Best answer by david_r
You can (among other things) configure your FlexNet licensing server to always give a specific license level to a specific machine.
Some documentation from Safe: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Restricting_Licenses_to_Users_or_Groups.htm
However, I recommend you look into LicenseAdministrator.pdf that is installed in the FlexServer/Documents directory on the license server, specifically chapter "Managing the options file" on page 147 for more detailed information.
