Can I make custom installed python packages available to all users under windows?
  • April 14, 2022
  • 103 views
I found in the documentation that the recommended destination for installed custom python packages is: Windows: C:\\Users\\<user>\\Documents\\FME\\Plugins\\Python
How would I make the packages available to all users of the computer?
Help page: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Installing-Python-Packages.htm
Best regards,
Stefan
virtualcitymatt
Forum|alt.badge.img+35
Take a look here, at the bottom there is a section about shared folders in fme
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Coordinate_Systems/Workbench/options_default_paths.htm
It does require that each separate installation has this shared folder configured. It should work for python modules as well as other fme specific things.
