What would be the fastest way to work out deltas between a feature service in portal and and the original dataset. We are talking about a table with over 700K records in it.
oscard
Forum|alt.badge.img+21
  • September 3, 2020
Sorry my ignorance, but by deltas do you mean changes? If that is the case, you could try the ChangeDetector transformer: http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/changedetector.htm
  • September 3, 2020
The change detector is all good, but I'm trying to find a way of reading a lot of records really fast. Especially when I'm dealing with hosted feature services. Cause there's no direct connect to the esri data store by design..
