Reserve licenses for certain workflows?
Not sure if it is possible but feel I can't be the only person with this question.
I have a standard FME Pro install with 8 worker license. Is it possible to reserve a couple of licenses so they will always be available for certain workflows that run as a cron jobs?
I basically don't want my cron tasks getting held up because other users run processes that occupy all 8 workers.
  • June 15, 2021
If you're talking about 8 floating licenses from a license server, then the process is described here:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop_Admin_Guide/FMEInstallation/Restricting_Licenses_to_Users_or_Groups.htm
If you're talking about the max. 8 parallel users of a single FME Desktop license on a machine with a fixed license (also called a node-locked license), then I believe it's not possible.
  • June 15, 2021
I was talking about the latter, I'll investigate floating licenses.
