2D lines to 3D Features
  • January 31, 2019
  • 6 replies
  • 126 views
Hello Everyone,
I am looking to convert 2D Lines to 3D Features. I am not looking though to add Height value, what I want to do is take a line and based on an attribute value (diameter: 250mm for example) create a 3D cylindrical version of it.
Then I will add elevation values using the 3D Forcer, that I am aware of.
I have taken a look at 3D Forcer/Interpolator, SurfaceDraper, etc. but I do not believe they do the trick.
Could you please point me to a direction?
Thank you for your time.
Kind regards,
George Floros
Best answer by daveatsafe
Hi @georgefloros,
The Bufferer transformer has a 3D option that allows you to build a cylindrical feature around a line.
The Hub3DBufferer custom transformer gives you more options, and is a lot quicker in the Fast Surface mode.
Forum|alt.badge.img+31
  • January 31, 2019
Have you looked at the extruder?
Hello @egomm,
Edited: I am looking to create a cylindrical feature based on specific values from 2D lines. I had tried the extruder, but it just gave me a height. Sorry, should have clarified.
Thank you,
George Floros
daveatsafe
Forum|alt.badge.img+19
  • January 31, 2019
Hi @georgefloros,
daveatsafe wrote:
Hi @georgefloros,
Hello @DaveAtSafe,
I actually had the same epiphany. Bufferer does the trick and thank you for the advice!!
daveatsafe wrote:
Hi @georgefloros,
Hello @daveatsafe
While bufferer oes the trick is quite slow.
I tried Hub3DBufferer and I get the following error:
Hub3DBufferer_Chopper(ChoppingFactory): Chopper encountered unsupported geometry, outputting as untouched
Input is FGDB lines.
Any recommendations?
Thank you.
Kind regards,
George Floros
daveatsafe
  • March 18, 2019
georgefloros wrote:
Hello @daveatsafe
Thank you.
Kind regards,
George Floros
Hi @georgefloros,
It's possible that the FGDB source lines contain arcs. Please send them through an ArcStroker, then GeometryRefiner to simplify the lines to be compatible with the Hub3DBufferer.
