FME Data Interoperability does not show in the extension list after installed by an administrator
My desktop administrator has installed the FME on the PC with Esri ArcGIS desktop. I'm not the administrator of the PC. After FME desktop installed, the FME Data Interoperability is listed in the Esri ArcGIS desktop extension for the administrator. When I login, my ArcGIS extension list doesn't include the FME data Interoperability. I'm not the administrator on the PC. Thus I don't have right to install any software. How can I use the FME Data Interoperability installed by the administrator in the ArcGIS desktop? Thanks in advance.
Helen
Best answer by david_r
Maybe also have a look at this article:
https://knowledge.safe.com/articles/1291/fme-extension-for-arcgis-not-showing-up-in-arctool.html
erik_jan
Forum|alt.badge.img+17
  • May 29, 2017
I believe this is a question for the ESRI forum, not for the FME knowledge board as the Data Interop extension is an ESRI product.
  • May 29, 2017
OK. thanks for the prompting answer. I will contact Esri.
  • May 30, 2017
  • June 1, 2017
Thanks David. Very helpful. I am in the middle of Esri and FME struggling. Your post is very useful.
Helen
