Do I have to configure anything in order to receive emails on FME Cloud?
  • April 27, 2016
  • 6 views
fmelizard
Forum|alt.badge.img+17
The FME Server Administrator's Guide indicates that configuration files must be modified in order to setup FME Server to receive emails:
FME Server Admin Guide: Configuring FME Server to Receive E-mail
Because the file system is not available on FME Cloud, is this necessary?
Best answer by rylanatsafe
FME Cloud has already been setup to receive emails! Following this email tutorial, in 'Option A: Direct email to FME Server via SMTP Relay' you can enter any text for the Email User Name parameter (e.g. demoEmailUser).
e.g. If your FME Cloud URL is https://myFMECloud.fmecloud.com/fmeserver, then the email address will be m
rylanatsafe
Forum|alt.badge.img+13
  • January 13, 2017
