I am reading an excel file, and seems most datetime fail to read
It shows for example HH:MM:SS for 5PM as 166000, and therefore it fails converting it, because 60 minutes is not valid.
'20181007166000' is not an FME datetime. YYYYMMDD, HHMMSS[.X+][(+/-)zz] or YYYYMMDDHHMMSS[.X+][(+/-)zz] expected. Use a DateFormatter transformer to adjust the format of datetime strings.
any ideas
