From string type to double type and reduce the decimals
I have an attribute (string type) with values such as 37908.907836. If I use an AtributeRounder, I can reduce it to 37908.907. That's ok. But if I convert the string type to double type, the decimals comes again...
I have tried to convert first and to apply the AttributeRounder later but it doesn't work. Any suggestion?
Thanks!
Best answer by david_r
This is unfortunately the way floating point numbers work in computers, see https://floating-point-gui.de/
  • May 29, 2020
Oh! I didn't know that! Thanks a lot for the answer!
