I'm using FME server to execute a workspace when an email arrives. I have configured a notification and it works fine, my workspace is launched.
My workspace fails sometimes when I try to read an attachment in my workspace. The error message indicates that the file can't be read. This problem occurs because FME server downloads the file in a temporary folder that has the same name as the email subject. If this subject contains special characters (such as ?), the workspace can't access to that directory, due to encoding problems.
Is there a way to configure the directory in which the attachement are downloaded? I've tried to use the "Download Attachments To" option while creating may Email Notification, but Fme Server stills create subfolder.
I've also tried to use Automations, but it doesn't work because I may receive several attachments in the same email, and automation is unable to process multiple attachments.
How can I solve my problem?
