I’m new to FME tool and I wanted to pull data from Google BigQuery tables and convert into GeoDatabase and shapefile. I'm using FME Workbench version 2024.1.1 and I'm experiencing an issue with using Google BigQuery as a reader. But I’ve installed Google BigQuery as a transformer and attempted to pull data, but no data is being retrieved. I’ve also authenticated using a service account key file, but the data still isn’t showing up.
