Send emails using Deployment parameter
asablomberg
Forum|alt.badge.img+7
I made a deployment parameter with some email-addresses in but when I use it to send emails I get an error in the automation log, see below. I have commas between the addresses in the parameter.
Default Recipients    : deployment.Fel_mail_adresser        <-------this is my parameter
Sending email with subject "abcd..." to recipient(s) "deployment.Fel_mail_adresser" …
An exception occurred. Invalid Addresses
Failed to send email.
Best answer by david_r
Make sure you only have a single comma and no space between the email addresses. Sometimes this can make a difference for the mail server.
  • March 25, 2024
asablomberg
  • March 26, 2024
Thanks! That was it.
