Tiling space delimited XYZ Files
  • November 22, 2017
  • 10 views
I have a number of space delimited XYZ files (DTM data) and need to merge them and then split them into 1km x 1km tiles. The final dataset needs to be an .xml file that Civils 3D can use and produce a surface out of it.
I've used the tiler transformer but i'm running into errors during/after the tiler process
Any thoughts? Am i missing something in the process?
jdh
Forum|alt.badge.img+28
  • November 22, 2017
It would be helpful if you said what exact error you encountered is.
fmelizard
Forum|alt.badge.img+18
  • November 25, 2017
Hi @jb_gisb1 If you suspect a problem with FME then please send us some sample data and your workspace via www.safe.com/support Thanks!
