How to pass only the value of a manual key from a webbook or manual trigger automation to the next action?
  • June 6, 2023
  • 11 views
When I create a manual trigger automation and pass in a single key value pair as a manual Key, the complete json for the key seems to be pass to the next action in the automation. The next action is a submit job action that takes a single published parameter (VERSION).    Is there a way to bind just the value from the manual key to a published parameter in the next action (Run a workspace action)?
I created a manual trigger with a manual key called MANUAL_KEY.
In subsequent actions, I apply the MANUAL_KEY from the trigger to a parameter in the action using the pattern “Manual.MANUAL_KEY” the resulting value is complete JSON and includes KEY name and value.
imageThis results in the full json passed in as the published parameter in the workbench action :
 "MANUAL_KEY": "Example value"
Is it possible to bind only the value?  Something like “Manual.MANUAL_VALUE.Value” ??
Which would pass only “Example value” into the published parameter of the next action?
I have tried to search for the answer to this but haven’t found anything so maybe this isn’t possible. If not, what is the recommended approach?
Thanks,
Ali
This was caused by a simple mistake. The reason json was being passed to the action was because I was typing json into the trigger input field of the manual trigger when I could have just entered the value. A post request requires json as the body of the request but the when using the server UI to trigger the automatio just enter the value of the key and it appears to be passed to the actions.
