Correct method for tracking automation failures
olly_egw
Issue: During the Christmas break, one of our automations failed regularly due to an account issue. I did not get any notifications and only upon my return and a manual review did I see this issue.
Question#1 : What is the correct method for tracking automation failures. Can the system send email notifications with the associated error message. If so, how do I do this ( note: my knowledge in the product are still basic )
Question#2 : We are scanning workspace logs from the logs folder , but where are the automation logs ?
Many thanks in advance for any assistance
Oliver @ EGW
stefanh
Forum|alt.badge.img+8
  • January 3, 2023
Question #1:
In the Automation you can add a new action after running a workspace. There you choose the action 'Send an email'. And fill in the parameters.
imageQuestion #2: An automation starts a workspace (or several workspaces). The logs of these workspaces you can find in the jobs-menu / jobs-folder. I don't believe there are logs for the automation.
olly_egw
  • January 3, 2023
Many thanks @stefanh​ for the quick response.
I have now made the changes to my automations. It's alittle administrative if I had alot of automations , but quiet a simple, customisable solution.
FYI: You can view the log using the Menu on the automation which has the option 'View Log File'. I was hoping to use a workspace to review the log file and send appropriate alerts, hence the question where this data is stored. Probably stored within the FME server Db.
olly_egw
  • January 4, 2023
did some digging around and found the logs at
$(FME_SHAREDRESOURCE_LOG)/core/current/automations 😀
stefanh
  • January 4, 2023
Glad the issue is solved.
I have seen the 'View Log File' but haven't used it; maybe I should :-).
In the past we created a workspace which automatically added the Email-action (with the correct parameters) in an automation. We used an template so every error-email had the same information. This workspace uses the REST-API and an JSON-updater to add / update the Email-action.
Recently we changed this procedure due to the amount of emails we got from the automations. Now we have a daily workspace running that digs through the logfiles and extracts all errors / fails. Then an email with a summary of al the issues is send in the morning.
