Hi, How can I copy data from say a CSV file with one record too many records from another file? If you have a common record header you can use the feature merger but I don't have anything common. Is there a way to do that?
jan-henk
Problem
Best answer by jdh
You can use the featureMerger.
you can set both the requestor and supplier join on values to a constant like 1 rather than an attribute.
jdh
Forum|alt.badge.img+28
  • October 23, 2020
jan-henk
  • October 24, 2020
Thanks thats is a nice trick 👍
