AreaGapAndOverlapCleaner
  • September 18, 2020
  • 19 views
HI,
I have couple of elements in microstation DGN, there is overlap error in a element (x=105676.2218, y=64384.1729 ) . I need to remove that overlap automatically. Both elements are of type Complexshape. I tried the transformer AreaGapAndOverlapCleaner but ended up with failure . I am sending the DGN file as well as workbench. Kindly help me to resolve this issue.
Forum|alt.badge.img+35
What sort of failure are you seeing? The workspace provided resolves the overlap for me
