Force error when source table doesn't exist or attributes are missing
tfcw
Participant
  • Participant
I have a lot of workspaces running off a lot of Oracle tables in a lot of different databases. When I run a workspace in which an attribute defined in a Reader doesn't exist in the source, I get this message in the log:
2021-01-06 11:31:24|   1.4|  0.0|WARN  |Oracle Reader: Column 'COLUMN_2' specified on Feature Type but does not exist in table 'TEST' and will be ignored
When I run a workspace in which the table no longer exists, or I lost access to it, I get no message at all and the workspace just treats it as reading 0 rows from the source.
Is there a way to configure FME so that these cases will cause the translation to fail? I know I can do post reading checks to make sure rows came through and each attribute isn't missing, but I have a whole lot of these so it would be nicer if there was just a switch I could flip somewhere.
Best answer by markatsafe
@tfcw​ There is no simple switch I'm afraid. But we recently presented a webinar on these very ideas.: Database Tips & Tricks: Strategies for Detecting and Handling Schema Drift. So have a flick through that to see if there is anything that helps.
As a starting point, FeatureReader returns both the features and the schema metadata, so comparing those will get you part of the way.
  • January 6, 2021
  • January 7, 2021
If you need to stop on missing input tables, make sure that "Ignore failed readers" is set to NO under Workspace Parameters / Translation.
