FME 2020: How to label the output in the graphic part based on particular field?
  • January 30, 2021
  • 5 replies
  • 137 views
jamal
Forum|alt.badge.img+5
For example, in the screenshot below, I wanted to label the polygon based on the “parcelnumber” field but couldn’t figure out how to perform this
Clip_321
Best answer by nielsgerrits
You could try the LabelPointReplacer or the Labeller.
nielsgerrits
Forum|alt.badge.img+54
  • February 1, 2021
jamal
  • February 7, 2021
Thank you. It works fine
Clip_365
jamal
  • November 2, 2021
Not sure if there is a way to label the polygons but not the points as we do in ArcGIS Pro
Clip_1061Clip_1062
danminneyatsaf
Forum|alt.badge.img+12
Clip_1061Clip_1062
Hi @jamal​ it looks like you're pretty close. I can't see the rest of your workspace so this might be similar to what you have already done, but one suggestion you could try is a CenterPointReplacer to replace the center of the polygon with a point, and then use a LabelPointReplacer to replace that point with a Label.
jamal
  • November 20, 2021
Is there any chance to have a dynamic label that moves inside the polygon according to the level of zoom as in Pro?
Clip_1168Clip_1169
Clip_1170
