I'm trying to map a Smallworld table to a different schema in our Postgres SDE. I have one Excel file with the schema for the writer and another Excel file with a worksheet for mapping from the smallworld field to the fields that exist in the schema for the writer. This works when I translate to ffs (even though I get some error messages). But when I use the same workspace to translate to Postgres SDE it fails. Eventually I will need to map multiple Smallworld tables to the Postgres SDE. I have attached the workspace, the log file and the two Excel files. I'm wondering if having two excel files is part of the problem. But when I tried to accomplish all this with a single Excel file I was getting errors. Thoughts?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
