How to share publicly a published FME service,
jamal
Forum|alt.badge.img+5
I’m not sure how to share publicly a published FME service. as I wanted to access a particular fme service, I’m required to push logins as shown in the screenshot below.
How to make the fme service executed with no logins?
Best answer by itay
If you are using FME Server 2019.0+ have a look at this article: https://knowledge.safe.com/articles/94277/fme-server-apps.html
itay
Forum|alt.badge.img+17
  • August 31, 2019
alaa_flaifel
Thanks for the answer itay.
We'll check it.
itay
  • September 1, 2019
We'll check it.
You are welcome
alaa_flaifel
Hi Itay
Although I'm using FME sever 2019, I couldn't find the "create an FME server app" option under the Run workspace page nor the "Server Apps" in the navigation panel.
What could be the issue here?
Best,
Alaa
itay
  • September 2, 2019
Hi @alaa_flaifel,
THe FME Server Apps are available on 2019.1+, on earlier versions you should see a shareable URL in the workspace advanced properties (left of the question mark in your image - share this workspace)
alaa_flaifel
itay wrote:
Hi @alaa_flaifel,
Thank you.
Yes, I tried the shareable link & it worked well.
I will check the last version to try the server app.
alaa_flaifel
It worked well in 2019.1.1 too.
itay
  • September 2, 2019
Yes, it is a very nice addition to FME Server.
